Battery draining
180,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
CRFLEX
I parked my car for winter and it started up fine. Before then I did have some issues here and there with my battery draining/not cranking, so I bought a new battery. Today I got my battery charged because I went to start my car but there is no power at all when I turn the key. I don’t know what to do. I feel it may have something to do with wiring but the wiring is an absolute disaster in my car. I also suspect there is something causing my battery to deplete and I don’t know what to do about that either.
Apr 14, 2021 at 6:18 AM
  • 110,248 POSTS
It sounds like a parasitic draw. The easiest thing to do is remove one of fuse at a time to see which fuse stops the draw. Then, you will know which components to check.
Here is a link that explains how to do this. Take a look through it and let me know if it helps.
https://www.2carpros.com/articles/car-battery-dead-overnight
Apr 15, 2021 at 10:29 AM
