No power?
9,213 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
EMMANUELNGANDU
  • 29 POSTS
Kindly asking for a wiring diagram for the car listed above engine (P10A) eleventh generation 2021.
Mar 23, 2023 at 7:29 AM
  • 110,248 POSTS
I'm not sure why this isn't being repaired under warranty. It is still under full warranty. However, I will be happy to provide what I have.
I attached the power distribution schematics below. However, I have to say that the only engine I am showing is the L4-2.0L (K20C2).
I checked through the different model civics, but that is the only one listed.
joe
Mar 23, 2023 at 11:35 AM
EMMANUELNGANDU
  • 29 POSTS
At first, I wasn't given the full information but after asking the guy who sold it, he said that they changed the engine.
That's the root of the problem after checking the car I found out that even the rev counter and the speedometer aren't working
I couldn't see the engine number of the engine they fitted I will let you know when I see it, if at all its compatible.
Mar 25, 2023 at 6:24 AM
  • 110,248 POSTS
Let me know what you find as far as engine size is concerned. Also, did he explain why the engine was replaced on such a new vehicle?
Mar 25, 2023 at 2:03 PM
