No power
1,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DAVID LAPIER
No power to the car, no dinging when I put the key in the ignition, no power to the positive or negative when I use a tester. i jumped it let It idle for a while. Tried starting it the next day and nothing. mileage is around ninety thousand.
Nov 10, 2017 at 4:21 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
No power to the positive and negative what?
Nov 10, 2017 at 4:32 AM
DAVID LAPIER
Jumper terminals from the battery.
Nov 10, 2017 at 4:41 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I do not see these listed. where are they located?
Nov 10, 2017 at 4:46 AM
DAVID LAPIER
They are under the hood .positive is buy the fuse box the negative is above the driver side wheel.
Nov 10, 2017 at 4:52 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
How much voltage does your battery read? If you do not have a voltmeter and just a twelve volt test light. does it light bright when hooking it up right to the battery?
Nov 10, 2017 at 5:21 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If your alternator is not recharging the battery, make sure that fusible link #26 (120A) is not bad. It is located right there are the positive battery post.
Nov 10, 2017 at 5:31 AM
