No power
124,000 MILES • 2.0L • 4 CYL • RWD • MANUAL
SEAN HALL
Van runs on tick over.but do not rev up I change petrol filter cam sensor and crank sensor air mass sensor plugs and leads clean throttle body thanks sean
May 4, 2016 at 5:39 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge in USA auto parts rent gauge if this is a diesel do the same but we don't have thatmodel in US that year.
May 4, 2016 at 5:47 AM
  • 31,937 POSTS
Throttle position sensor may be faulty, a scan will show up on live data if you are getting correct throttle percentage , look into this.
May 4, 2016 at 6:21 PM
