No power?
2004 NISSAN MAXIMA
130,000 MILES • 3.5L • V6
DTAMERAS3
It seems like when you drive a manually shift car. And start out in third instead of first. Slow to get up to speed. I already replaced the #2 cam sensor. That didn't work. Unless the car needs to be manually somehow put out of slump mode? Lastly, I do have an exhaust leak somewhere I wouldn't think that would slump the car until a certain speed.
Oct 1, 2022 at 4:47 PM
  • 110,194 POSTS
You are correct about the exhaust leak. It won't cause it to go into limp mode. In this case, what you need to do is have the can-bus scanned for diagnostic trouble codes.
CAN stands for controller area network. Basically, all the computers/modules are tied together via a few wires. This type of scan will retrieve diagnostic trouble codes regardless of the module storing them.
Here is a link that explains how it's done:
By chance, have you had this done? You indicated two cam sensors being replaced. Did you have codes that indicated a problem with the sensors?
Oct 1, 2022 at 7:30 PM
