Ok. So I am lost. While driving at highway speeds all my guages and radio went out. Lights and truck still drove fine..a few moments later everything back on...then off again. This happened for about 30 minutes as I made my way home. About a mile our complete shut down. No crank no seat. Had to tow. So I have worked on it. PCM was dead. Or so I thought. I have a new PCM, Alternator, battery, throttle body. What I have found. When throttle body is plugged in no PCM and throttle body actuator clicks and spins. Unplug actuator and PCM comes on and truck will start but wont stay running due to throttle body not working. I get the same results if I unplug the first big Plug on the left of PCM. Also doors will lock but only drivers door will unlock fob or door switch. Pedal adjuster and drivers seat. I hear a clicking under the seat but no movement. I have traced wires. I have 12v to pins at PCM All ground wire grounds have been checked. Power to actuator. Only consistent thing is. Throttle body plugged in no PCM no start no crank. Hear relay trying but nothing else. Unplug throttle body. PCM works crank and start. I am lost someone please help.i have .any pictures and know enough but this is kicking my butt. Can show or answer anything specific but this is long already.
Nov 26, 2026 at 6:17 PM
