No oil pressure
260,000 MILES • 6.0L • 4 CYL • 4WD
FREESTYLEFRANK
Engine shuts off as soon as I start it. I know this is a safety feature for the engine. I have changed the oil pump, cleaned the oil pan and pump screen. I am at a loss.
Please note: This vehicle is an eight cylinder not a four cylinder.
Oct 5, 2019 at 1:28 AM
Good evening,
This sounds light a security issue, not an oil pressure issue.
Does the theft light go off after the key is turned on in about 10 seconds?
https://www.2carpros.com/articles/how-to-reset-a-security-system
Oct 5, 2019 at 8:54 AM
FREESTYLEFRANK
Yeah, the theft light is not illuminated.
Oct 5, 2019 at 10:11 AM
Okay, then the next step is to do a manual oil pressure test to see if it is either a real oil pressure issue or the sender unit is sending a false signal.
Remove the sender unit and insert a manual gauge and crank up the motor and see if it has oil pressure.
Oct 5, 2019 at 10:00 PM
FREESTYLEFRANK
Thanks, I'll give that shot.
Oct 5, 2019 at 10:50 PM
You are welcome.
Keep me updated.
Oct 5, 2019 at 10:57 PM
