My car broke down due to lack of oil going into my front top cylinder. The cam wear down the center cam seating in the top cylinder due to lack of oil going into the cylinder head. We later fix the oil pump which is the culprit. But we decide to grind the worn seating to clear it from contacting the cam. This will allow the cam to only rotate on for settings two by the right and two by the left. Will this work? And what effect will this have on the top cylinder performance?
Feb 11, 2017 at 6:21 AM
