started ticking, oil pressure dropped truck shut off and will not start
150,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
HATCHCARTER
my truck started to make a ticking sound and the oil pressure dropped and the truck shut off and wont start again. the dipstick shows no oil but i had just put two quarts in within the hour. i couldn't get it to start so my dad had to come and tow me home. what can i do to see what really happened and if the motor is in need of replacement?
Dec 23, 2019 at 11:54 PM
Good morning,
Does the engine turn over when you crank it?
Do you see any signs of leaking?
Dec 24, 2019 at 1:06 AM
HATCHCARTER
It doesn’t turn over almost like the battery is dead and no signs of leaking.
Dec 24, 2019 at 5:15 AM
Okay, it may be locked up.
You should try to turn the engine by hand to be sure the engine turns.
Dec 24, 2019 at 5:27 AM
HATCHCARTER
Looking down on the motor what way should the ratchet move?
Dec 24, 2019 at 5:31 AM
Either way. It does not matter. Just make sure the engine can turn.
Dec 24, 2019 at 5:46 AM
