short at fusible link to junction box. no low beams. changed light switch, and two new headlights. I cannot find no relays, fuses, etc..
Jul 12, 2016 at 2:11 PM
CARADIODOC
✓Experienced Mechanic
If the headlight switch was defective, you would not have high beams either. Have you considered the dimmer switch? If that does not pan out, or if you want to do some testing first, which is the way professionals would approach this, do you have a voltmeter or test light and know how to use them? I will dig up a wiring diagram if necessary.
Jul 12, 2016 at 2:15 PM
RENEE L
MEMBER
Hi BIGCAMAROMAN,
I am sending you a link to useful and informative information on how to use a voltmeter/multi-meter. This is an easy step by step guide on how to use a voltmeter; this information pertains to all car related applications. Most voltmeters/multi-meters are fairly inexpensive to purchase and you can purchase one online from sites like Amazon.com. I have also included a link to how to use a test light article from this site.
