No lights on Climate Control?
5,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
COOTERBROWN
  • 14 POSTS
I installed the factory Kicker Subwoofer for Bose models Silverados. Once I connected the battery back up and crunk to test, the sub worked fine, however there are no lights (power) to the climate control section. The blower is running but no buttons light up or control any functions.
Dec 12, 2020 at 7:39 AM
COOTERBROWN
  • 14 POSTS
Update: I checked all of the fuses and they were good. So, I disconnected the negative battery terminal and left it disconnected for 20 minutes. Upon cranking, all climate control functions operated normally. However, now it says it does not recognize the key fob even though I can unlock the doors with it and also remote start with it.
Dec 13, 2020 at 12:01 AM
Okay. We need to let the vehicle sit overnight so that it can go through a sleep cycle and then allow the modules to boot back up. This vehicle operates off what is called a CAN network. That means the modules communicate with each other through this system and it sounds like there is some "confusion" on the network.
This may be caused by the addition of the sub but I doubt it.
Here is a guide that talks more about this system:
What I am hoping that after the body control module powers down and goes to sleep (that is what it is called, going to sleep) and then powers back up that the configuration will be correct.
If it is not we may need to contact the dealer and ask they add a sales code for the sub so that the vehicle knows it is there as it just sounds like each time you disconnect the battery that something else stops working. That is a sign of a configuration issue. However, let's try this first and see what happens. Thanks
Dec 13, 2020 at 4:09 AM
COOTERBROWN
  • 14 POSTS
Thank you. I will see what it does in the morning and report back. Much appreciated for the info.
Dec 13, 2020 at 7:54 AM
COOTERBROWN
  • 14 POSTS
KaseKenny1,
The problem persists. The truck still does not recognize the fob.
Dec 14, 2020 at 3:06 AM
Okay. This may be a coincidence but we may have to unhook everything you installed when this happened but let's not go there yet.
Can you tell me everything you put in? Was it just a sub and wiring or were there other components as well?
Also, the other thing I am thinking is we just had an issue when connecting the battery again and it has nothing to do with what you put in the vehicle.
Lastly, does the vehicle actually start or it says the key is not recognized and does not start but all the functions work like the locks and remote start? Just trying to fully wrap my head around what could have happened. Thanks
Dec 15, 2020 at 10:07 AM
COOTERBROWN
  • 14 POSTS
See pic for reference. I will explain exactly how this installed. All is GM factory harness to make this as true plug and play there is. Power wire from battery plugged into main harness. Ground attached per GM instructions. Tapped into the speaker wire per instructions. Ran harness from front to back and plugged harnesses into sub and amp per instructions. Reconnected negative battery terminal and climate control section did not work. Next day, removed negative battery cable for 2O minutes and reinstalled. Climate control worked properly, and this error message starting coming up.
Everything on the remote works. When doors are locked, the unlock button on the door handle does not work because the truck is not recognizing the fob. When I try and start the truck, error message of truck not recognizing a fob appears and I have to put the fob in the relearn position (cup holder) and the truck will start.
I’m tempted to take the negative battery cable off again but I’m worried that something more important will not work.
Dec 15, 2020 at 12:48 PM
Okay. I think this has more to do with the battery disconnect then the addition of the sub.
So the way this key works is the vehicles has antennas placed around the vehicle and it looks at signal strength of the key on each antenna and it uses this to triangulate where the key is. It needs to see the key inside the vehicle in order to start the vehicle. Can you get a picture of where this key is and what the message is stating?
Does it say it is not recognized or not detected? The fact that you can put it in the cup holder and the truck sees the key tells me it is not detecting it. There is an antenna just below the cup holder so you are basically placing the key directly on top of the antenna and so it is able to see the signal strength strong enough to know if it is inside the vehicle.
I suspect this vehicle is still under basic warranty since it is about a year old and such low mileage? If it is I would take it into the dealer and show them what it is doing. Again, I don't see how this would be related to the speaker so it should be covered. Plus you used all OEM parts so they can't say it is some aftermarket part.
It would be a pretty big coincidence but I think that is what we have. The climate control not working was related to the battery disconnect and that was corrected. So again, if anything this is related to disconnecting the battery but I can't see how it is related to the speaker.
Dec 16, 2020 at 9:36 AM
COOTERBROWN
  • 14 POSTS
It does indeed say the key is “not detected” and then the image below pops up. The key is in my lap at that time. Once I put it in the cup holder, the truck will start. The truck is under warranty, I just purchased it new in July ‘20. It has 5,000 miles on it. I guess my only option at this point it to take it into the dealer. Oh yeah, should I try and replace the battery in the fob? Both fobs are getting the same message. but I guess it doesn’t hurt to try.
Dec 16, 2020 at 10:12 PM
It is highly unlikely in your situation that this is a battery issue in the fob not only because those batteries have about a 7 year life span on them but as you said, both are doing it.
You have most likely an antenna issue. One more question, when you installed the sub, where did you put it and did you happen to take any connectors apart? I am wondering if we didn't get one of the antenna connectors completely snapped back together.
The reason I ask, is there is no question that at this point the vehicle is not able to locate the key as being inside the vehicle so it gives you this message. So that means we have either an antenna issue or module issue and it would make sense if we unhooked one and didn't get it back together.
Let's chase this down before you go to the dealer because if they find it, they will charge you as that is not a defect. So let's go from there and if this is not it then I am sure it would be warrantable.
Dec 17, 2020 at 9:40 AM
COOTERBROWN
  • 14 POSTS
I did not unhook anything, however, I did think the original issue of the climate control was a fuse issue. I checked all fuses that are associated with the climate control as well as some others. Are there fuses that control these antennas? That might make sense, possibly pulled one and didn’t get in all the way or in the correct location?
Dec 19, 2020 at 3:46 AM
COOTERBROWN
  • 14 POSTS
Think I’ve narrowed it down. I’ve noticed my dash cams have not been coming on. They are powered by an expansion battery which is on a switched fuse. The plug on the battery to the camera comes unplugged rather easily and I’ve not checked until today. The camera is not unplugged which means I am not getting power from the switched fuse. After checking the fuse location with my voltmeter, I am not getting a voltage reading. See attached picture, it is F27&28 (50A-APO rap/batt). I do not know where the power for this fuse originates but it surely has to be the issue. Any ideas?
Edit: If looking at F27/F28 the far right pin does have voltage but the middle and far right do not.
Dec 19, 2020 at 5:34 AM
Okay. If that is the case, let's start at the very beginning of this issue because at this point we are going blind trying to figure out possible issues. if you have no power there, then I suspect you have a code that will point us to where we need to go. Specifically a B code if I am correct that this is an antenna issue.
Here is the testing for your issue of No Key Detected. As you can see with this testing there are codes that go with it so let's see what we have in the truck and then we can continue to with that specific testing.
Dec 19, 2020 at 11:18 PM
COOTERBROWN
  • 14 POSTS
How do I figure out if there is a B code? Have to use a scanner?
Dec 20, 2020 at 1:57 AM
Yes. Sorry meant to include a guide that will help with that.
If you don't have one, most parts stores will do this for free. Some have stopped offering a free service but I am sure there are some that do in your area.
Dec 20, 2020 at 2:45 AM
COOTERBROWN
  • 14 POSTS
I’m not reading any codes. I can only read with the switch off or with the truck running. I cannot just turn on the auxiliary power (which illuminates the lamps such as check engine) due to the truck not detecting the fob.
No DTC’s are reading.
Dec 20, 2020 at 6:19 AM
Okay. I don't have any question at this point that this is not related to what you installed. However, if you look at the second page I attached before and you will see where it says if there are no DTCs to proceed with testing. Basically it is asking to check key fob operation. Does it lock and unlock? If so, try to start the vehicle. If it does not start then it wants you to program the keys again. You need a scan tool that can do that so it may need to go to the dealer if your tool doesn't do that.
Dec 20, 2020 at 9:16 AM
COOTERBROWN
  • 14 POSTS
Before I do that, that doesn’t explain why I’m not getting voltage at the previously mentioned fuse location. My dashcams were working for over 6 months and now when this happened, I’m no longer getting voltage at this location.
Update: I forgot to mention. When I took my truck in for an oil change, the tech informed me the battery has a bad cell. I could not leave my truck at that time and have not been able to return. Do you think that may play a role?
Dec 20, 2020 at 10:05 AM
Sorry. I jumped over that. I can't find any documentation on it but I think that is because you are starting in a limited mode due to it not recognizing the key.
I know other OEMs have the same thing. Like with Chrysler vehicles, if your key fob battery is drained, you can take the key and hold it against the button to start the vehicle and it will start but you lose some options and get a message on the cluster. This is basically to force you into the dealer to get it addressed. I believe that is the reason for this but again, I can't confirm this because there is no documentation on it in the manual.
Dec 20, 2020 at 11:32 AM
COOTERBROWN
  • 14 POSTS
I reprogrammed both fob’s and the same message continues to appear. I used instructions from the following link: https://www.programautokeys.com/classified/2020-chevrolet-silverado-ignition-transponder-chip-key-programming-instructions-listing-9332.aspx#.X-ApVOQ8KaM
Both fob’s sill function as normal but the truck does not detect them why trying to start the engine.
Dec 20, 2020 at 12:51 PM
Okay. That process is not listed in the manual which is not surprising because those are intended for the dealer and not the DIYer.
However, that is good info because if programming the keys does not solve it then it is the module most likely that is at fault.
This is one of those situations that I cannot explain why it happened but it appears to be a coincidence or something happened when connecting the battery to cause this to fail. We have established pretty clearly that what you have installed is not the cause.
Dec 21, 2020 at 10:44 AM
COOTERBROWN
  • 14 POSTS
To the dealer she goes. Thank you for all of your help. I’ll update this once the dealer corrects the problem.
Dec 21, 2020 at 11:17 AM
Sounds great. Thanks. We wait to hear the result on this one!
Dec 21, 2020 at 11:40 AM
COOTERBROWN
  • 14 POSTS
I never got a straight answer out of my dealership but I think it was a combo of 2 things:
A module went bad. They didn’t tell me which one and a cell was bad on the battery, they replaced the battery and now everything works correctly.
Apr 22, 2021 at 2:42 AM
That is great. Thanks so much for coming back and providing that info. Shorted cells in the battery cause all sorts of crazy issues so I am glad you provide that info which will help others in the future. Thanks for using 2CarPros.
Apr 23, 2021 at 12:05 PM
