No working lights. none of my lights work on the dash or outside.
Nov 26, 2019 at 6:37 AM
✓Experienced Mechanic
If all light are affected, there is only one common element with them, the headlight switch. The switch is powered via a fuse. Check that first. If it is good, I suspect the switch is bad.
The fuse is in the vehicle, left side of dash. It is fuse number 14, a 15 amp fuse.
