No left turn signal/brake light
86,000 MILES • 6.0L • V8 • 2WD
FROSTYBUSY
Left side only. Turn signal front and rear not flashing either with turn lever or emergency flasher switch. No rear brake light either. New bulbs. Manual shows location 21 in fuse box under hood but no fuse in 21. Did not show fuse in box under driver seat either.
May 4, 2019 at 3:41 AM
FROSTYBUSY
Solved problem. #7 fuse that protects the BCM5 was weak.
May 5, 2019 at 7:20 AM
  • 55,682 POSTS
Sorry we could get to you fast enough. Good to hear you got it fixed, please use 2CarPros anytime we are here to help.
May 6, 2019 at 8:12 AM
ROBERT BRINKLEY
Thank you all so much. I was having the same problem with my 2017 Chevrolet Express (No turn signals, flashers or brake lights on left side). Tried for 4 hours to locate the problem then found this feed from FROSTYBUSY and solved it in 5 minutes.
Jun 25, 2021 at 6:50 AM
  • 55,682 POSTS
I don't see the feed?
Jun 28, 2021 at 2:02 AM
