No left hand turn signal working via indicator or hazard warning
98,000 MILES • 1.5L • 4 CYL • 2WD
MOREHELPME
Replaced passenger door mirror after a collision and found later no indicators on left side at all.Cannot find if there are fuses for left and right.
Fuse box in with glove box and fuse is okay.Not found diagnostic socket to run a scan for possible body module issue.Later google image shows port under the mug holder.
Oct 5, 2019 at 2:50 AM
STEVE W.
  • 15,401 POSTS
Welcome to 2CarPros. Renault is one of the companies that doesn't release a lot of the repair data to anyone outside of the dealer network. That makes it difficult to determine what issues are. In this case I would think the issue is likely in the control for the turn signals was shorted out in the collision. However without good wiring diagrams it is difficult to determine what is wrong.
Oct 9, 2019 at 5:46 AM
MOREHELPME
Yes, when i rang Renault they said they needed to see the car for wiring issues. i might get car in and run diagnostics or see if live data can see something. thank you.
Oct 9, 2019 at 6:44 AM
STEVE W.
  • 15,401 POSTS
You're welcome, hope they figure it out. Thank you for using 2CarPros.
Oct 9, 2019 at 8:50 AM
MOREHELPME
Got car into garage and diagnostics run and many errors,all erased except 1 and car now has working indicators.
Oct 10, 2019 at 8:14 AM
STEVE W.
  • 15,401 POSTS
Sounds like the typical modern car. Good to hear they work. Thanks you for the reply and for using 2CarPros.
Oct 10, 2019 at 10:47 AM
