No key stuck in park, location of shift cable disconnect needed
2008 HONDA PILOT
100,000 MILES • 4WD • AUTOMATIC
LAURA HUGGINS
MEMBER
1 POST
Where is the shift cable disconnect for this vehicle. I lost the keys and need to roll it out of the garage for towing. Thanks!
Apr 18, 2019 at 5:50 AM
JIS001
✓Experienced Mechanic
Normally there is a little door by the gear selector you pop off and push a button inside to move the gear selector to neutral. Tow companies know about this and should not be a problem.
Apr 18, 2019 at 4:40 PM
