No juice to injector 4
CHEVYJ
  • 15 POSTS
Thanks for all ur help its very much appreciated
Friday, February 26th, 2016 AT 6:27 PM
CHEVYJ
  • 15 POSTS
Well I'm back after installing the new pcm I had a code for a camshaft circuit low voltage so I changed the sensor and it still says the same thing camshaft circuit low voltage what could this be
Sunday, February 28th, 2016 AT 6:24 AM
CHEVYJ
  • 15 POSTS
Also would a computer from a manual cavalier work in a automatic
Sunday, February 28th, 2016 AT 6:25 AM
CHEVYJ
  • 15 POSTS
Could I have gotten a bad computer it starts but shuts right off
Sunday, February 28th, 2016 AT 6:35 AM
CARADIODOC
  • 33,873 POSTS
Diagnostic fault codes never say to replace parts or that one is bad. They only indicate the circuit that needs further diagnosis or the unacceptable operating condition. When a part is referenced in a code, it is actually the cause of that code only about half of the time. You also have to consider corroded connector terminals and cut or rubbed-through wires.
Three-wire magnetic position sensors usually develop a square-wave signal that bounces between 0 and 5 volts. I'm not sure what it takes to set the code you have. Other sensor signal voltages are usually limited to a range of 0.5 to 4.5 volts. 0 volts is not an acceptable voltage and is what it takes to set the code you have. There's two ways to look at that signal. One is with an oscilloscope which is built into a lot of newer scanners. The other is to view the sensor on a scanner's screen, then look at whether it is listed as "No" or "present". That is how it's done with my Chrysler scanner. That scanner will work on other brands of vehicles but with reduced functionality.
The best I can suggest is to measure the three voltages by back-probing the sensor's connector. The voltages will only be accurate when the sensor is plugged in. You should find 5.0 volts on the feed wire, and 0.2 volts on the ground wire. If those are right, measure on the signal wire. Expect to see that voltage change if you turn the engine a little by hand.
If the signal voltage stays at 0 volts before condemning the sensor, check the 5.0 volt feed terminal to be sure it's not spread and failing to make contact with the mating pin.
Sunday, February 28th, 2016 AT 3:24 PM
