Wil not start, It cranks good fuel pressure?
334,000 MILES • 2.0L • TURBO • AUTOMATIC • DIESEL
CHRISANDERSEN
  • 8 POSTS
After battery fail it deleted key programming. Now it wil not start. Keys programmed no immo fault. It cranks good fuel pressure
Oct 11, 2026 at 5:36 AM
  • 55,849 POSTS
Do you have a flashing security light on when trying to crank the engine over? We need to see what codes you have, here is a video to help us start fixing the issue.
https://www.youtube.com/watch?v=LBCpCWEFnTg
I have three questions:
1. What is the actual fuel rail pressure in bar while cranking?
2. Does the scan tool show engine RPM while cranking?
3. Are there any PCM trouble codes, even though the immobilizer shows no faults?
I am particularly interested in the rail pressure and engine RPM readings. Those two values will help us separate a fuel injection problem from an electrical or programming issue.
Oct 12, 2026 at 10:15 AM
CHRISANDERSEN
  • 8 POSTS
550 bar in rail
No pcm codes
250 rpm on crank
No immo light
Suspect injector drivers
Oct 12, 2026 at 10:25 AM
CHRISANDERSEN
  • 8 POSTS
Injectors are not getting any signal on crank. Scanners i use is forscan and icarsoft max. Strange thing is fs says both keys are pressent in all slots but icarsoft say there are no keys stored
Oct 12, 2026 at 10:30 AM
  • 55,849 POSTS
Okay, so disconnect one of the fuel injector connectors and check if you have 12 volts/power to one of the wires with the key on.
Oct 13, 2026 at 6:32 AM
  • 55,849 POSTS
It sounds like the injector driver is out though, but you may have a shorted injector which can cause the injector driver to stop working.
Oct 13, 2026 at 6:33 AM
CHRISANDERSEN
  • 8 POSTS
Piezo injectors no constant 12v with key on
Oct 13, 2026 at 6:34 AM
CHRISANDERSEN
  • 8 POSTS
Ohmed all injectors no short
  • 55,849 POSTS
I don't have this vehicle in the states so I can see the wiring diagrams to see how the system works. Can you recheck the fuses in the main fuse panel?
Oct 13, 2026 at 6:35 AM
CHRISANDERSEN
  • 8 POSTS
All fuses are tripple checked all are good. No wires are broken.new bcm installed and programmed
Timing checed 4 times crank sensor checked good sinus wave. Sanity checked not good
Oct 13, 2026 at 6:40 AM
  • 55,849 POSTS
Haha, yep these kinds of repair can be frustrating. It sounds like you are correct, that the injector driver module has gone out.
Oct 13, 2026 at 6:49 AM
CHRISANDERSEN
  • 8 POSTS
Okay. Wil plukk my self an ecu then. Thanks for the help
Oct 13, 2026 at 6:51 AM
  • 55,849 POSTS
No worries, let me know what happens after yo get the new part installed.
Oct 13, 2026 at 6:56 AM
CHRISANDERSEN
  • 8 POSTS
Mey take some time. Wifi not happy about me bying carparts
Oct 13, 2026 at 6:58 AM
  • 55,849 POSTS
Yep, I hear ya.
Oct 13, 2026 at 7:13 AM
