After idle relearn, no idle is given to the car so the car engine shuts off.
Oct 7, 2018 at 12:10 AM
✓Experienced Mechanic
This sounds like you have an air intake boot that is cracked or disconnected or the throttle bore needs to be serviced or you have a large vacuum leak. Here are two guides to help us find and fix the problem:
