check to make sure both hoses going to heater are hot then try unplugging hvac fuse for 60 seconds with key on it may reset the air mix motor as that may be the problem so no heat.it's fuse 3 and 6 in car this is for manual heat only. This sounds like you have low engine coolant or the temperature blend door actuator stopped working but to but sure this video and guide can help us fix it.
https://youtu.be/SNRb6pSwYuU
and if the temperature blend door needs replacement here is a guide that can help with diagrams below to show you on your car.
This guide can help as well
https://www.2carpros.com/articles/car-heater-not-working
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
May 24, 2021 at 12:27 PM
