No heat or defrost
283,757 MILES • 4.9L • V8 • 2WD • AUTOMATIC
RLBROWN11691
my fan is blowing but no heat or defrost comes out of vents.
Oct 11, 2019 at 2:00 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you're having a problem with the blend door/mode valve actuator.It's an electrical motor that opens/closes an air door to direct air flow throughout the duct work/vents.Here is a tutorial showing what's involved to remove/replace:
I've attached a picture below showing its location in the HVAC box located under the dash board.Hope this helps and thanks for using 2CarPros.
Danny-
Oct 11, 2019 at 7:33 AM
