No heat or defrost
100,000 MILES
HOODAS
  • 5 POSTS
Fan is not kicking on at all not even on high. So I am thinking it is not the resistor. Is there anything else I should check before pulling out the glove box and replacing motor?
Nov 8, 2018 at 4:11 AM
  • 110,248 POSTS
Before you remove the motor, check fuses. Check both fuse 20 and 21 in the passenger compartment fuse box. I attached a list of what each fuse is for as well as the layout of the fuse panel.
Here are a couple links that will help if you have trouble:
https://www.2carpros.com/articles/how-to-check-a-car-fuse';
___________________________
If you find the fuses are good and there is power to the motor, here are the directions for replacement. First is a link that shows how one is replaced in general. Following the link are the directions for your vehicle.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
The aforementioned link is for motor replacement.
REMOVAL AND INSTALLATION
Blower Motor
1. Disconnect battery ground cable.
2. Remove glove compartment.
3. Remove heater duct.
4. Disconnect intake door motor and blower motor electrical connectors.
5. Remove blower motor retaining bolts and the blower motor.
6. Reverse procedure to install.
___________________________________
Let me know if this helps of if you have other questions.
Nov 9, 2018 at 8:54 AM
HOODAS
  • 5 POSTS
"Hey Joe", lol. Little "Hendrix" pun intended. Thanks for getting back to me super busy today. I will check out all the links tomorrow, and let you know. Thanks again man. I am sure it will be a Huge help. Have a great day.
Nov 10, 2018 at 6:05 AM
  • 110,248 POSTS
No problem, and when I was young, I watched Hendrix a million times to learn how he played certain guitar licks. LOL He taught me a lot!
Let me know how things go and if the links are helpful. I agree with you that if the fan does not even work on high, chances are it is not the resister.
Regardless, I will watch for your reply. Let me know if I can help or if you need additional information. I will clear the purple haze from my computer screen and reply.
Nov 10, 2018 at 11:07 AM
HOODAS
  • 5 POSTS
Mr.Joe. Thanks again for your time. I pulled the blower motor, once removed applied power, no movement. Tapped motor housing a few times with screwdriver motor tried to turn. Got new motor, of course they gave me wrong part. lol. Housing bracket did not line up. Plugged it in anyway. It was working like a champ. FYI, looks like for a 1994 Subaru Legacy wagon, you cannot buy the complete assembled unit. Have to buy motor, and fan separately.
Peace~
Nov 11, 2018 at 2:11 PM
  • 110,248 POSTS
Welcome back:
Honestly, often times, the motor is separate from the fan itself. You should be able to remove the fan itself from the motor and reinstall it on the new motor. I attached two pictures for you to see. Look closely at the center of the fan. You can see on this motor there is a clip that holds the fan blade on the motor. It can be removed. See if your design is similar.
Let me know if you run into trouble.
By the way. Love the site. Is that your band? For some reason, I can hear the audio fine, but my screen is extremely blurry. It sounds like the doors. Is it or is it your band?
Nov 12, 2018 at 9:09 AM
HOODAS
  • 5 POSTS
Hey man. Motor should be here tomorrow. Took old motor apart. Pulled the clip cut wires at brushes, shrink tubed connections at clip.. gonna but splice new motor wires.
That is my personal website. I am a full time musician in Seattle. That site has my original music, and several cover bands, rock, funk, etc. Sounds like you were checking out Alive She Cried one of the Doors tribute bands I am in.
Thanks for having a look. I will let you know how it turns out.
Nov 12, 2018 at 10:05 AM
  • 110,248 POSTS
Sounds like a plan. And yes, I was checking out the site and very impressed. I have played in bands since I was 12. My parents had to go because I was too young to be in the bars. lol Everything from lead, bass, drums, keys I have done. Until 16, I was first chair violinist in the Westmoreland County Youth Symphony. However, it was not cool to play violin, so I quit. Ugh! I have a ton of originals. Maybe someday I will get to play full time, but at 54, I do not think it is likely.
Nov 12, 2018 at 11:37 AM
HOODAS
  • 5 POSTS
You have my e-mail Joe. Shoot me a personal e-mail if you like. We can chat music-n-such.
Nov 12, 2018 at 11:53 AM
