Heater and A/C are not working
90,000 MILES • 2.5L • 2WD • AUTOMATIC
ENGRTUCKER
have no heat no ac just air blowing through front vents. switch will not shut off nor go to defrost no matter what button i press. mechanic ran codes and reset some to try to get actuator to work says no power to them thinking maybe wiring harness need help here please someone rescue me.
Dec 17, 2021 at 9:57 PM
  • 110,248 POSTS
I'll try my best to help. I need a little more information. First, you mentioned that he ran codes. Do you know what they are? Also, does the vehicle have automatic or manual climate control?
There are a number of things that can be causing issues. However, without the codes, it becomes a guessing game. The idea that the fan won't turn off and you have no control over the airflow direction could be related to what is called an AC amplifier or the controller itself. I don't suspect a wiring issue at this point, but it is possible.
Let me know which system you have and what codes were retrieved.
Dec 18, 2021 at 2:50 PM
