No heat on passenger side
94,000 MILES • 6 CYL • 4WD • AUTOMATIC
TJWILSON
What would cause no heat from passenger side vents? It only blows out cold air. The driver side and rear vents do blow out heat.
Dec 2, 2019 at 8:32 PM
Good morning,
There is a blend door actuator that controls the heat and cold command. It looks like it has failed.
This is a very common failure. I attached the picture and procedure for replacing the actuator. It is located behind the glove compartment door s shown in the picture.
Dec 2, 2019 at 8:56 PM
