no heat but get hot temperature gauge Rises
170,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
MCPATTEN
change thermostat flash radiator top hose hot but bottom cloud
Mar 15, 2014 at 11:43 AM
TY ANDERSON
  • 719 POSTS
Air in the cooling system will cause no heat to come out of the dash vents & overheating. So when engine has cooled sufficiently check the coolant level. If that is good there is a possibility the water pump has failed causing no coolant circulation. This would cause overheating and no heat from dash vents. That is really it unless the thermostat could be installed backwards but I doubt that.
Mar 15, 2014 at 12:08 PM
