HVAC vacuum line diagrams
123,456 MILES • 3.0L • V6 • FWD • AUTOMATIC
EMCGRAIL
Heater core replaced and thermostat replaced. Radiator flush and nothing still no heat in 3-4 years. now I need more help.
Jan 17, 2015 at 9:43 AM
HMAC300
  • 48,601 POSTS
check for a vacuum leak as it is vacuum motor operated the heat door may not be opening start at engine then to control head. pic shows vacuum lines item with arrow is for blend door.
Jan 7, 2021 at 2:45 AM
TTONKA42
I have a 2001 ford taurus. When i turn on the air conditioning or the heater it only blows out of the defrosters. Panel floor vent will not work. A friend of mine said change the blend door and i did and i found out that all it does is regulate the heat and cold air ( 50.00 part wasted ) Another person said look for a vacuum line, i did and found a very tiny one hanging off the passenger side firewall but don't know where it goes. Sorry for the frustration but i'm a funeral director not an auto mechanic.
Jul 28, 2021 at 6:01 AM (Merged)
CARADIODOC
  • 34,417 POSTS
There's is a small vacuum hose that is disconnected probably under the hood headed into the fire wall on the passengers side. Look for a small check valve to plug that hose into. It will be somewhere near or on the firewall near the rear edge of the hood, and it could be about the size of a stack of three nickels with a port on each side, or it could be the style with a built-in storage chamber.
That one is about the diameter of a quarter and about 1 1/2" long, again, with a port on each end. Your car might also use a much larger type of vacuum storage canister with the port for the hose. Vacuum-operated systems are spring-loaded to go to the defrost position when vacuum is lost. Your feet might freeze but the windshield will be clear.
Here are some vacuum diagrams (below) to help you see what needs vacuum. If you need to run a new hose to the control head to fix the problem.
Cheers, Randy
GRABBER
Good afternoon,
I have the identical problem with a 98 Sable. Is the vacuum line that you are discussing on the outside firewall or inside (under the dashboard?
Any help is appreciated...July will be here very soon.
CARADIODOC
  • 34,417 POSTS
Both. It starts at the engine, goes to a storage canister or check valve, then goes through the firewall to the heater controls.
GRABBER
Thanks. I found the line from the check valve that points straight down is only about 8-10 inches long and either broken or disconnected (hard to tell by looking at it). I was having a tough time finding where the end of this hose goes to until I looked at the diagrams you have above.
I will have to check the firewall very closely again and leave an update...or any hints at where I may find the entry point to the inside of the vehicle?
CARADIODOC
  • 34,417 POSTS
It should be either right at the firewall center where the heater hoses go into the car or at the passengers side outer firewall.
JGONZO2398
  • 375 POSTS
Had this same exact problem on my 2002 Ford Taurus, took it to Firestone for a diagnosis, they told me it was three different things, wanted to charge me $700. One of those things was the cabin air filter, replaced that (since it was just full of crap), fixed my problem. I'd suggest to start there, $10 fix.
CEDDY2_
  • 21 POSTS
i have a ford taurus the issue im havin is, i cant direct my heat to the floor or vents. i have changed the selector switch and the blend door actuator is there somethin im missin ? i checked the blend door for movement and its not jammed moves freely, also heat works fine i just cant direct it . any help wud be great. 2001 ford taurus 3.lt
thanx
FIXITMR
  • 9,989 POSTS
this is a vacuum operated system here is a diagram. check supply line in engine compartment.
CARADIODOC
  • 34,417 POSTS
That filter affects how much air can get through, not which vents it comes out of, but it wouldn't surprise me if there was enough debris built up to where it blocked a mode door.
Happy to hear you found an inexpensive solution.
CEDDY2_
  • 21 POSTS
Thanx alot guys, looked under the hood and traced vac lines i had a broken vac line, thanx for the info.
GREAT JOB
JGONZO2398
  • 375 POSTS
Sounds like it wouldn’t make sense I know, but I had that same exact problem and the cabin air filter fixed my issue, I even changed the blend door actuator before that but that didn’t even help. I’d say it’s a good place to start
  • 55,859 POSTS
Good call, thanks for the input. Please feel free to help out whenever you are on the site :)
Cheers, Ken
RPAYNE1969
going thru a rainstorm the other day and had to turn off the air conditioner and turned on the defroster. tried to turn the air conditioner back on and it would only blow out heat. the condenser for the air conditioner is working and it is full of Freon but will still only blow out hot air. I was told it could possibly be the a/c control module but I do not know where it is located under the dash to try and change it on my own. Please advise. I'm from up north and this Florida weather is unbearable without the ac. We would appreciate any help with this issue. Thank you!!!
HMAC300
  • 48,601 POSTS
check for a vacuum leak first start at engine then to ac heat control at the back( the buttons or knobs you turn or push.) then see if item 10 is working in drawing it will be a vacuum motor and shold pull the door so only ac will come thru.
BAESHAWNFRYAR
tiny vacuum line the runs into firewall that controls/regulates climate control. what does it connect to / how do i reconnect?
CJ MEDEVAC
  • 11,000 POSTS
The small line connects to the intake manifold look for other vacuum lines and it should be there. here is the HVAC vacuum line diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
BAESHAWNFRYAR
Thanks, this site rocks!
CJ MEDEVAC
  • 11,000 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
