No heat and overheating
91,000 MILES • 4 CYL • AUTOMATIC
BLANE APOSTADIRO
My car keeps overheating. The hot air from the A/C is now blowing cold and it just started today out of the blue.
Mar 21, 2018 at 11:07 PM
  • 31,937 POSTS
Check for low coolant, check that the thermostat is opening. if coolant is low, get a cooling system pressure test done to find any external leaks and a head check done to test for exhaust gasses in the cooling system. this will indicate an internal leak, start here.
Mar 21, 2018 at 11:25 PM
