No heat and AC only blows ice cold
247,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
RUSTY2400
No heat and AC only blows ice cold. I have a digital temperature control or climate control and if the AC is running it only blows ice cold air in the matter which temperature I select. Any help would be greatly appreciated.
Sep 24, 2018 at 5:41 AM
  • 110,248 POSTS
I think you have a problem with the air mix door actuator. The component is responsible for opening and closing an HVAC door which determines the air temperature entering the vehicle. Under the left side of the glove box, locate the air mix control motor. See pic 1
Turn the system on and change the temperature and feel if the motor is running for a short time. If it isn't, most likely it needs replaced.
Here are the directions from Alldata for replacement. See pic 2
1. Disconnect the connector from the air mix control motor, then remove the self-tapping screws, the air mix control motor and the flange collar.
2. Install in the reverse order of removal. After installation, make sure the air mix control motor runs smoothly.
_____________________________________
I don't know if this will help, but this link explains the purpose of the air mix door (blend air door) and in general how one is replaced.
I hope this helps. If you have other questions, let me know.
Sep 24, 2018 at 11:30 AM
RUSTY2400
Thanks for commenting, I found this YouTube video that I am going to try. It sounds like it will be the solution to my problem.
https://youtu.be/CjclEh9pawY
Thanks, Russ
Oct 20, 2018 at 3:46 AM
