Before I parked my car the heater was working when I started the car the heater would not blow hot air
56,000 MILES • 3.4L • V6 • FWD • AUTOMATIC
ORTHODEVIL
Heater was working fine. Came out from shopping and heater was not blowing hot air. AC works fine. The position selector runs through all positions without a problem. I have check fluid level it was a little low so I topped it off bleed the air out of the system as best I could. I noticed this morning that there was still a little air sputtering but not a lot mainly fluid. Any suggestions on what I need to do
Dec 17, 2016 at 1:25 AM
HMAC300
  • 48,601 POSTS
pressure check system for a head gasket leak pressure testers may be a rent item at auto parts. make sure it is full prior to test
Dec 17, 2016 at 2:50 AM
