HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Montana
Climate Control
Heater
Not Working
No heat
PREV
1
2
NEXT
MECHANIC
Anytime.
Monday, March 30th, 2020 AT 5:25 PM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Heater Not Working Content
Heater Not Working
Heater Blows Cold Air Most Often. Occasionally It Will Blow Hot Air But Changes Back And Forth While Driving Or Sitting Still. Today The Van...
Asked by
Harrell96
2003
PONTIAC MONTANA
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
Heater Will Blow Cold Air And Sometimes It Warms Up...
Heater Will Blow Cold Air And Sometimes It Warms Up, But Mostly Cold, What Could Be Problem
Asked by
Anonymous
1 IMAGE
2003
PONTIAC MONTANA
2000 Pontiac Montana Tried Everything, What Now?
I Changed Intake Gasket Last July. Everything Worked Fine Until About Oct. Occasionally It Would Overheat, And The Heater Blow Cold. Always...
Asked by
ajring
2000
PONTIAC MONTANA
I Am Having Heater Air Flow Problems In The Cabin.
The Filter Is Missing And The Actuator Seems To Be Operating Correctly. Since It Is Only A Problem On The Heat Side, Could The Heater Core...
Asked by
Rick S.
1 ANSWER
1999
PONTIAC MONTANA
2000 Pontiac Montana Heater Only Works At High Rpms
At Idle The Heater Blows Cold. Go Down The Road Or Just Raise The Rpms And The Heater Blows Warm. Does Anyone Know What The Little Pump Is...
Asked by
jring94
1 ANSWER
2000
PONTIAC MONTANA
VIEW MORE
Heater Not Working
Blend Door Actuator Replacement
How to Replace Damper Door Switch
