no heat
240,000 MILES • 5.9L • 4WD • AUTOMATIC
77MARINE85
i have a Cummins. change heater core no heat . installed flush t and flushed no heat. not over heating. thermostat is working as well as the water pump. AC works . by pass door works. read that the AC/heater fan switch could be the culprit, because it actuates the AC compressor and a motor that switch air from heat to the evaporator. i do not know how to test the switch . any thoughts would be appreciated. driving around with a propane heater is getting old.
Feb 9, 2017 at 6:05 AM
HMAC300
  • 48,601 POSTS
I am assuming you mean no heat in truck. first check cable for blend door to see if it is broken or not operating the blend door so you can get heat.
Feb 9, 2017 at 11:34 PM
