No heat
211,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
NANA LOVE
  • 7 POSTS
How do I know if my water pump isn't working? I have lukewarm air in my cab. Both hoses get hit. Replaced thermostat. Still not hot air. Help!
Jan 28, 2021 at 12:49 AM
Good afternoon,
This could be either a heater core or a blend door actuator. Make sure the cable is moving the blend door when you change from heat and cold and back.
I would remove the hoses from the firewall and use a garden hose to flush the core. Flush it back and forth several times until you get a clean even flow.
https://www.2carpros.com/articles/replace-heater-core
https://www.2carpros.com/articles/car-heater-not-working
https://www.2carpros.com/articles/replace-heater-hoses
If this does not work, the heater core may have to be replaced.
Warning: on vehicles equipped with airbags, failure to take the proper precautions could result in accidental airbag deployment and possible personal injury.
REMOVAL
1. Remove the heater-A/C housing from the vehicle, and remove the housing cover. Refer to: "Housing Assembly HVAC : Service and Repair" See: Housing Assembly HVAC > Service and Repair
Heater Core Remove/Install
2. Lift the heater core out of the heater-A/C housing.
INSTALLATION
1. Insert the heater core into the bottom of the heater-A/C housing.
2. Reassemble and reinstall the heater-A/C housing in the vehicle.
The heater-A/C housing assembly must be removed from the vehicle and disassembled for service access of the blower motor, blower motor wheel, heater core, evaporator coil, blend-air door, and each of the various mode control doors.
REMOVAL
1. Disconnect and isolate the battery negative cable.
2. Remove the instrument panel from the vehicle. Refer to: "Body and Frame : Interior Moulding/Trim : Dashboard/Instrument Panel : Service and Repair" See: Dashboard / Instrument Panel > Procedures
3. If the vehicle is not equipped with air conditioning, go to Step 6. If the vehicle is equipped with air conditioning, recover the refrigerant from the refrigerant system. Refer to: "Heating and Air Conditioning : Service and Repair" See: Heating and Air Conditioning > Service and Repair
4. Disconnect the liquid line refrigerant line fitting from the evaporator inlet tube.
5. Disconnect the accumulator inlet tube refrigerant line fitting from the evaporator outlet tube. Install plugs in, or tape over all of the opened refrigerant line fittings.
6. Drain the engine cooling system. Refer to: "Engine, Cooling and Exhaust : Cooling System : Service and Repair" See: Cooling System > Service and Repair
7. Disconnect the heater hoses from the heater core tubes. Install plugs in, or tape over the opened heater core tubes.
Heater - A/C Housing Remove/Install
8. Remove the four nuts from the heater-A/C housing mounting studs on the engine compartment side of the dash panel.
9. Remove the nut that secures the heater-A/C housing mounting brace to the stud on the passenger compartment side of the dash panel.
10. Pull the heater-A/C housing rearward far enough for the mounting studs and the evaporator condensate drain tube to clear the dash panel holes.
11. Remove the heater-A/C housing from the vehicle.
REMOVAL
2. Roll down the instrument panel assembly, but do not remove it from the vehicle. Refer to: "Instrument Panel, Gauges and Wiring Indicators : Instrument Panel : Service and Repair" See: Instrument Cluster / Carrier > Service and Repair
3. Disconnect the temperature control cable from the heater-A/C control.
Temperature Control Cable Remove/Install
4. Disconnect the temperature control cable housing flag retainer from the receptacle on the top of the heater-A/C housing.
5. Pull the temperature control cable core self-adjuster clip off of the pin on the end of the blend-air door lever.
6. Remove the temperature control cable from the vehicle.
INSTALLATION
Temperature Control Cable Self-Adjuster Clip
Before installing the temperature control cable, be certain that the self-adjuster clip is properly positioned. This measurement must be made with the cable end bottomed against the flag retainer on the heater-A/C control end of the cable housing. The measurement is taken from the end of the flag retainer on the heater-A/C housing end of the cable to the center of the self-adjuster clip. If the self-adjuster clip is not properly positioned, slide the clip up or down the cable core as required to achieve the specified dimension.
1. Push the temperature control cable core self-adjuster clip onto the pin on the end of the blend-air door lever.
2. Snap the temperature control cable housing flag retainer into the receiver on the top of the heater-A/C housing.
3. Reinstall the instrument panel assembly. Refer to: "Instrument Panel, Gauges and Wiring Indicators : Instrument Panel : Service and Repair" See: Instrument Cluster / Carrier > Service and Repair
4. Connect the temperature control cable to the heater-A/C control.
5. Connect the battery negative cable.
6. Adjust the temperature control cable.
Jan 28, 2021 at 3:34 AM
NANA LOVE
  • 7 POSTS
What if the radiator hoses aren't getting hot?
Feb 3, 2021 at 10:41 AM
That could be the thermostat or it could be an indication of a failed head gasket.
I would have a leak down test done to verify that there is not a head gasket leak into the cooling system.
A leaking engine cylinder head gasket usually results in loss of power, loss of coolant and engine misfiring.
An engine cylinder head gasket leak can be located between adjacent cylinders or between a cylinder and the adjacent water jacket.
- An engine cylinder head gasket leaking between adjacent cylinders is indicated by a loss of power and/or engine misfire.
- An engine cylinder head gasket leaking between a cylinder and an adjacent water jacket is indicated by coolant foaming or overheating and loss oil coolant.
CYLINDER-TO-CYLINDER LEAKAGE TEST
To determine if an engine cylinder head gasket is leaking between adjacent cylinders; follow the procedures outlined in Cylinder Compression Pressure Test. An engine cylinder head gasket leaking between adjacent cylinders will result in approximately a 50-70% reduction in compression pressure.
CYLINDER-TO WATER JACKET LEAKAGE TEST
WARNING: Use extreme caution when the engine is operating. do not stand in a direct line with the fan. do not put your hands near the pulleys, belts or the fan. do not wear loose clothing.
Remove the radiator cap.
Start the engine and allow it to warm up until the engine thermostat opens.
If a large combustion/compression pressure leak exists, bubbles will be visible in the coolant.
If bubbles are not visible, install a radiator pressure tester and pressurize the coolant system.
If a cylinder is leaking combustion pressure into the water jacket, the tester pointer will pulsate with every combustion stroke of the cylinder.
Feb 3, 2021 at 6:01 PM
NANA LOVE
  • 7 POSTS
No leaks in head gaskets. Radiator is cool while hoses are warm. Does that help any?
Feb 4, 2021 at 6:57 AM
You need to start somewhere. I suggest you flush the core, as I suggested and replace the thermostat.
Feb 4, 2021 at 7:23 AM
NANA LOVE
  • 7 POSTS
Thermostat was changed out and I checked the old one and it was still good.
Feb 4, 2021 at 8:17 AM
Okay, and the heater core?
Feb 4, 2021 at 8:19 AM
NANA LOVE
  • 7 POSTS
Going to try and flush tomorrow if weather let's me. Very frustrating...
Keep me updated.
Feb 4, 2021 at 6:06 PM
NANA LOVE
  • 7 POSTS
Flushed it today. Changed the heater hoses cause I just wanted new ones.
Feb 5, 2021 at 7:57 AM
NANA LOVE
  • 7 POSTS
Tomorrow we shall see... Thanks for getting back to me.
Feb 5, 2021 at 7:58 AM
You are welcome.
Always glad to help.
Feb 5, 2021 at 8:05 AM
