No heat
152,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JDL980306
My front and rear heat does not work and it will also slowly overheat. I have changed the radiator, the thermostat, the water pump and blew out both heater cores.
Feb 6, 2019 at 7:39 AM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
It sounds like there is a possibility that you have an air pocket in your cooling system. This is especially likely with a dual heater core system such as yours. The symptoms you have described really sounds like low coolant which air pockets could cause. I have attached a link for our tutorial for flushing and filling the cooling system. I would recommend flushing the system as added assurance, however I would strongly recommend following the fill procedure at the end:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Feb 6, 2019 at 8:53 PM
