Remove both hoses and use a garden hose and flush out the core. Go through both sides until you have an even flow.
Sep 4, 2019 at 3:43 AM
OSEPHUS
MEMBER
Roy, aren’t both hoses supposed to be hot?
Sep 4, 2019 at 7:00 PM
✓Experienced Mechanic
One should be hot and the other is cooler.
Sep 4, 2019 at 7:09 PM
OSEPHUS
MEMBER
Okay, thanks. I’ll try it today. one other question, is there a way to adjust the idle or do I have to get the idle speed control motor?thanks Roy.
Sep 4, 2019 at 10:17 PM
There is a procedure for that. The motor has to be retracted and the base isle set. Then the motor is run out to full length and is adjusted to a spec at that point. Those idle motors were a common failure.
