No heat from heater
122,000 MILES • 4 CYL • AUTOMATIC
AMUNN
Thermostat has been changed heater core flushed out antifreeze is full what can it be? Is there a wire or a fuse I should be checking? The blower works just blows cold air.
Nov 5, 2016 at 5:55 AM
JIS001
  • 3,412 POSTS
There is a cable that controls the temperature door. Remove the glove box and the climate control assembly. Verify the cable did not come off the retaining clips.
Nov 5, 2016 at 7:15 AM
AMUNN
I will try that next thank you.
Nov 5, 2016 at 7:34 AM
  • 55,743 POSTS
Hey AMUNN,
This sounds like you have one of two things going on, first you may have a blend door actuator that is not working, next you could just need the climate control reset, Pull the fuse for the climate control for 5 mins to see if that fixes it, if not here is a guide for the blend door actuator.
Please let us know what you find so it will help others.
Best, Ken
Nov 7, 2016 at 2:01 AM
