No heat
101,098 MILES • 6 CYL
ANTHNOY1
The heater is blowing no heat is kicking out. I did change the climate controller and the thermostat, both heater core hoses are running hot but still no heat.
Nov 24, 2019 at 7:57 AM
ANTHNOY1
Yes, I do hear the doors move when I go from AC to heat. the air blow strong just no heat is coming out. both of my heater core lines are hot. do you think it could be one of the small vacuum hoses that are located by the heater core hose?
Nov 24, 2019 at 8:40 AM (Merged)
Good evening,
I found there was an update for the deflector door or the blend door on the heater box.
I attached the TSB for it and a picture.
Do you hear the door move when you command heat and AC and back again? If you do then it is working.
If you do not then good chance the heater core is clogged. I would remove the hoses and run a garden hose through the core back and forth several times until you get a good even clear flow.
88chrysler14
Models
1988 C-G-H-J- & P-Body Passenger Cars and N-Body Truck
Subject
Warm Air From Demister Outlets
Index
AIR CONDITIONING
Date
December 12, 1988
No.
24-02-88 REVISION A
(C24-05)
Technical Service Bulletin Date 10/17/88 is being revised to include Figure 1. Figure 1 was inadvertently left out during the original printing and distribution of Technical Service Bulletin 24-02-88.
SYMPTOM/CONDITION
Warm air coming from the side window demisters when the climate control system is operating in the A/C panel mode.
DIAGNOSIS
Before attempting further repairs, it is important that the following action be taken to insure this condition is not caused by a misadjusted temperature door.
1. Verify that the temperature door is hard against its stops when the temperature setting on the A/C control panel is in the coldest (not recirculate) position. On standard A/C, this can be done by rapidly moving the lever to the minimum heat position. On Auto Temp systems, it will be necessary to set the control to 66 degrees. When correctly positioned, the door will emit a "thump" as it hits its stops. If necessary, adjust the cable auto-adjusting clip to obtain the desired results.
2. With the engine idling in park or neutral, operate the climate control system in the A/C panel mode at high blower speed and at minimum heat (not recirculate) until the A/C discharge air and engine coolant temperatures have stabilized.
3. Measure the temperatures of the left center A/C outlet and the demister outlet. If the demister air is more than 20 degrees warmer than the A/C outlet air, the bi-level air door and vacuum actuator should be replaced.
PARTS REQUIRED
4462526 Bi-level Door Assembly
4462918 Vacuum Actuator
REPAIR PROCEDURE
This repair procedure involves replacement of the bi-level air door and vacuum actuator which will reduce the temperature and the volume of the demister air anytime the system is in the A/C panel mode.
1. Consult the appropriate 1988 service manual for the proper procedure and then remove the A/C evaporator housing from the vehicle.
2. Using the procedure as outlined in Group 24 of the service manual, remove the bi-level air door and vacuum actuator from the evaporator housing.
3. Replace the existing bi-level air door with service replacement door, PN 4462526, as shown in Figure 1. Replace the vacuum actuator with service replacement actuator, PN 4462918.
4. Using the instructions in the service manual, reinstall the evaporator housing unit back into the vehicle. Complete all mechanical, vacuum, and electrical connections. Refill the engine with coolant. Evacuate and recharge the A/C system.
5. Be sure that the temperature door is adjusted properly and that all mode doors are functioning correctly.
6. Verify that the climate control system is operating satisfactorily by means of an overall A/C performance test as outlined in Group 24 of the service manual. If the climate control system does not pass the A/C performance test, the cause must be identified and corrected before delivering the vehicle to the customer.
POLICY: Reimbursable within the provisions of the warranty
TIME ALLOWANCE: Labor Operation No. 24-65-22-90 (C-G-H-J- & P-Bodies) . . . . 2.9 Hrs.
24-65-17-90 (N-Body Truck) . . . . . . . 2.1 Hrs.
FAILURE CODE: 59 - Internal Leak
Nov 24, 2019 at 8:41 AM (Merged)
ANTHNOY1
I do not hear the door when I switch from air to heat.
Nov 30, 2019 at 11:20 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your mode door actuator. Your vehicle's Heating Ventilation and Air Conditioning [HVAC] system uses little plastic motors called actuators to move the doors of the system to route heat and air into different ducts. In the diagrams down below I have included instructions on how to replace your vehicles blend door. Here is a generic guide explaining how to replace an actuator motor in the link below:
Please go through these guides and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
