No heat
150,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
HARTJEN
  • 11 POSTS
I recently had to replace my timing chain cover due to crack and leaking oil. Recharged the A/C system and it is working well. However, there is no/little heat when the heater is selected. If engine is warm it will blow warm air for a few seconds then it cools off. It is not A/C cold but definitely not warm enough to take the chill out of the air and make the car comfortable.
Feb 23, 2018 at 11:01 PM
  • 55,766 POSTS
It sounds like you have an air bubble stuck in the heater core, it happens. Start the engine and get it warm turn the heater on full blast then use a jack and raise the rear of the car up as high as it will go on the jack.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
This should release the air bubble.
This guide can help as well.
https://www.2carpros.com/articles/car-heater-not-working
Cheers, Ken
Feb 26, 2018 at 5:15 AM
