No heat?
238,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELIZABETH NICHOL-MANN
My A/C works, fans work on all speed settings, car does not overheat, blower motor works... But I have no heat. Just blows cold air.
Oct 2, 2022 at 11:50 PM
  • 55,770 POSTS
First with the engine cold check the coolant level, With the engine hot, see if the heater hoses are hot as well, if not you may have a clogged heater core, or the temperature blend door actuator is not working.
here is a guide to help you with the temperature blend door actuator location in the diagrams below:
https://www.2carpros.com/articles/car-heater-not-working
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Oct 3, 2022 at 8:44 AM
Coolant level is okay, heater hoses get hot too. Just no heat gets into the car.
Oct 3, 2022 at 12:58 PM
  • 55,770 POSTS
Yep, this means the temperature blend door actuator is not working, I would change it out.
Oct 4, 2022 at 7:23 AM
