No Heater?
150,000 MILES • 6 CYL
BILL THIELEN
I replaced my front heater core when it had gone bad. The Rear Heat still worked when the front heat didn't work. When I replaced my heater core the heat worked great. The last two weeks the heat Front and Back is blowing cold I have replaced my coolant The Blend Door I can move Manually and that is not the problem I checked the Front Heater Hoses and Both are hot in and out going The Temperature gauge is within normal range and heats up fine.
Help!!
Feb 6, 2016 at 11:55 PM
Good morning,
Make sure your coolant level is correct. A low level will cause this.
https://www.2carpros.com/articles/car-heater-not-working
Check the thermostat for being stuck open not allowing the coolant to heat up.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Beyond that, the cores could be clogged with dirt and debris. Did you flush the system of all dirt and debris when you replaced the heater core?
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Aug 1, 2021 at 8:20 PM
