Headlight relay location needed
74,000 MILES • 5.6L • V8 • 2WD • AUTOMATIC
SKINNER ETHERIDGE
Lost headlights put new ones in only getting 5 volts to back of new ones installed can't find relay.
Apr 27, 2020 at 10:34 AM
  • 55,694 POSTS
There is no headlight relay for this truck I would test through the dimmer and headlight switch. Here is a guide to help you and the headlight wiring diagrams so you can see how the system works:
Apr 29, 2020 at 3:02 AM
SKINNER ETHERIDGE
Thank you so much. it was dimmer switch. thanks again, Charles Skinner Etheridge
Apr 29, 2020 at 11:14 AM
  • 55,694 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Apr 30, 2020 at 2:54 AM
