My Low beams work and function as they should, when you try to flip to high beam little blue light appears on dash, but no lights. The fuse cluster is brand new. I spent the last couple of hours with a test light testing every port and think I found the culprit. There is a white and blue/purple(?) wire leading out of each headlight assembly. The one from the pass side heads over to the driver's side. I believe this is ground… maybe?? Can you confirm? Would a bad ground be causing these symptoms? Where does this actually ground out at? I Did some searching and couldn’t see it. Also, this truck has a Boss snowplow and has the snowplow relays. All of these relays are brand new, so I don’t believe one of those is causing this.
Sep 26, 2022 at 12:30 AM
