no gas to cylinder
70,000 MILES • V8 • 2WD • AUTOMATIC
RICHARD FROEBEL
put gas in throttle intake. runs and stops not getting gas to plug.
Jun 5, 2022 at 8:32 AM
We need to start with the basics. That means we need to find out if the pump is building any pressure at all.
If there is no pressure, then we need to remove the relay and jump power to see if the pump will come on.
If it doesn't then we most likely have a failed pump.
If the pump comes on, then we have a power issue and we need to check the fuse and relay.
I am attaching the wiring diagram below which will help with all of this but the most common cause of this is a failed fuel pump.
Running through this process will confirm this.
Let us know what you find, and we can go from there. Thanks
Jun 6, 2022 at 10:09 AM
