No fuel pressure
1998 BUICK PARK AVENUE
100,678,000 MILES • 3.8L • 6 CYL
CROUSETODD
Replaced fuel pump and still no pressure. How much pressure do I need to start car?
Jan 16, 2020 at 11:29 PM
Good afternoon,
You need to verify power is going to the pump itself.
I attached the circuit for the fuel pump. The relay is under the hood and you need to verify voltage to the relay. You will need a test light or a voltmeter.
Can you hear the pump run with the key on?
The pressure is 55 pounds.
Jan 17, 2020 at 1:08 AM
