After running out of gas it only runs when pouring gas in the intake?
130,304 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
NISSANNICEUN
The car ran out of gas out gas in acted like wasn't picking up fuel so put more. Then battery was drained from cranking only runs when pouring gas in the intake.
Aug 20, 2022 at 1:06 PM
  • 55,594 POSTS
Yep, when you run the car out of gas the fuel pump runs dry which can cause the pump to go out, when you turn the key on without cranking the engine over you should hear the pump run in the tank for about 5 seconds. If not, I would replace the pump. here is how in the images below.
This video will show you how to get the fuel out of the tank before you begin.
https://youtu.be/Q5MH2gnyFH0
Aug 21, 2022 at 3:54 AM
