I recently bought the truck from my uncle and he wanted to keep the 350 in it because it was his grandfather's. I bought a 305 and put it in there. It ran after we got it in there and we got the timing set good, but it was dark so I did not test drive it. I came back the next morning and it fired right up fixed a water leak from the thermostat housing and drove around the block it seemed like it was starving for gas. By the time I got back to his drive way it died before I could put it in park. I can hear the fuel pump kick on, but I is not getting any gas to the tbi or even the fuel filter does not even have a drop of fuel. The tbi has two gas lines one is a feed and the
other a return and the return line got bent. I do not know if that is the problem or what is going on with it, but I checked all the grounds and they are good. Hope someone can help me.
Jun 14, 2016 at 11:26 AM
