No fuel at fuel rail
163,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DAMON G
  • 6 POSTS
my fuel pump works and it sends fuel out of the fuel filter, but it is not reaching to the fuel rail. any one no what the problem could be?
Jun 19, 2019 at 10:51 AM
SCGRANTURISMO
  • 4,897 POSTS
You either are not getting enough voltage at the fuel pump and the pressure is too weak to make it to the fuel rail, or, more likely, you have a bend or kink, or crushed fuel line somewhere after the fuel filter and before the fuel rail. You have double checked the fuel filter, correct? Let's start by inspecting the fuel lines, and get back to us with what you find out, please. We can go from there.
Thanks,
Alex
2CarPros
Jun 19, 2019 at 7:22 PM
