No fuel at Schrader valve?
76,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
TIKITOON21
Changed fuel filter, checked high pressure fuel pumps, working fine. Still no fuel at Schrader valve.
Aug 29, 2024 at 12:08 PM
  • 110,248 POSTS
How was fuel pressure tested if there is no pressure at the Schrader valve? Did you check it at the filter?
Also, I attached a pic below showing the fuel pressure specifications. Is that what you are getting? Have you checked for a kinked hose? Do you hear the pump turn on when the key is first turned on?
See pic below.
Aug 29, 2024 at 12:56 PM
