no fuel
250,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
ED SAUNDERS
engine runs when I shoot fuel in throttle body, wont start when turning the key. changed fuel pump and filter, checked fuses and relay. I do not hear the fuel pump when I turn the key.
Aug 13, 2016 at 12:58 AM
HMAC300
  • 48,601 POSTS
check to see if inertia switch is engaged button should be down and check relay under hood to see if it is sending a signal to pump. inertia switch is behind right kick panel.
Aug 13, 2016 at 2:50 AM
