Will not start, not getting fuel?
190,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TASHA ONEAL
I removed both A/C compressor and alternator. bought wrong A/C compressor so I had to put the original back forgot to plug the alternator back in and the battery drained out. switched batteries drove home plugged alternator back in. I had taken the black breather assembly off the engine when I changed batteries because the battery was too big, but covered the intake hole of the breather with a towel. when I got home to plug my alternator back in my car would not start. not getting any gas.
Aug 24, 2021 at 9:23 AM
  • 110,248 POSTS
Which intake hole was plugged with a towel? Also, when you say it won't start, is the starter engaging and cranking the engine, or does nothing happen?
One last question. Did you check fuel pressure?
Here is a link that explains the most common causes of a crank no start condition:
Let me know the specifics. Also, I need to know about the towel.
Aug 24, 2021 at 2:09 PM
