No front side lights, no rear light (brake lights ok) and no interior light. Also no dash lights.
137,000 MILES
KIMANDRICHARD
I bought his truck without checking the lights, there are No front side lights, no rear light (brake lights ok) and no interior light. Also no dash lights. The truck drives fine and the main beam works fine.
Sep 28, 2013 at 6:28 AM
  • 31,937 POSTS
Probably a fuse or a faulty switch, check these first.
Sep 28, 2013 at 9:39 AM
KIMANDRICHARD
Hi, thanks for the info, we took the ac fuse and put it with in the tail light slot (which had blown), now all lights work with the exception of the interior which is prob the bulb. One of the rear lights flickers on occasion so we are going to check for a loose wire. Thinking thats what blew the fuse.
Thanks for your help.
Sep 28, 2013 at 7:47 PM
  • 31,937 POSTS
OK, all good then, thank you for using 2CP.
Sep 29, 2013 at 7:23 AM
