front brake replacement ?
56,000 MILES • TURBO • AUTOMATIC
ASPENADMIN
  • 20 POSTS
Hi, my front brakes are not working I think the pads are gone, I need to do brake service.
Jan 17, 2019 at 12:54 AM
By the brakes not working, I suspect you mean they are not stopping well or grinding when you press the pedal. If that is the case then yes, you need to replace them.
Here are a couple guides that will help with this:
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
When replacing pads and rotors, it is a good idea to flush the system and get new fluid in the lines.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Below you will find the process from the manual that will provide the info needed to complete this.
Please let us know if you have other questions. Thanks
Aug 1, 2021 at 9:57 AM
ASPENADMIN
  • 20 POSTS
Hi, sorry for the late reply. No actually the pads are not gripping to the wheel when i am pressing the brakes.
Aug 17, 2021 at 7:51 PM
Good morning,
If the pads are not contacting the rotor then it is either the calipers or the master cylinder not sending fluid to the calipers for activation.
https://www.2carpros.com/articles/brake-caliper-replacement
I attached the procedure for you for the replacement.
Aug 17, 2021 at 8:24 PM
ASPENADMIN
  • 20 POSTS
Hi. Sorry for the late reply. I guess i can drive with rear brakes only.
May 17, 2022 at 12:41 PM
No, you need all four wheels. Rear brakes ae not enough.
Do not drive the car until you fix the front brakes. It is very dangerous.
May 17, 2022 at 9:38 PM
ASPENADMIN
  • 20 POSTS
Well, to be honest with you i am still driving with the rear brakes only. And i can manage it pretty well. What do you mean by dangerous? The car is still stopping right?
May 18, 2022 at 7:17 PM
Not as well as using four wheels to stop the car.
You should not be driving the car.
May 18, 2022 at 9:10 PM
ASPENADMIN
  • 20 POSTS
Okay. thanks, Roy.
May 19, 2022 at 3:42 AM
